8 inch rear to a 9 inch
Discussion in 'General Maverick/Comet' started by ZaksComet, Jan 10, 2012.
  1. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    Looking for some help in regards to chaning my 72 Comet from a 8 inch rear to a 9 inch posi. Is there any car i should look at specificly for the rear axle? Any help would be great!
  2. yellow75
    Tillamook Oregon
  3. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I see that it only goes up to a 71 comet, will it be the same still since mines a 72?
  4. yellow75
    Tillamook Oregon
    Yes Mavs and Comets are all the same through out the years as far as width
  5. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    so if i find a 9 inch rear axle off one it should fit without a problem?
  6. yellow75
    Tillamook Oregon
    The chart show the width of different years of cars that had a 9 inch rear end in them, Mavs and Comets had an 8 inch rear end that was 56.5 inches wide.
    The car with the closest measurement is a 57-59 Ranchero or station wagon and they are 57.25 wide. But a 65-66 Mustang and a 63-65 Fairlane are the same at 57.25 but good luck finding one of them.
    Lots of info on this site if you use the search forum.
    Why do you want a 9 inch anyway ? Unless you have a lot of horsepower you dont need one. 8 inch rearends will take quite a bit of power
  7. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    I want one bc I want to turn it into a posi and to do that with an 8 inch is looking really expensive to find the center that I would need. Talking to a friend who restores old cars said just switching to a 9 would be cheaper bc their so common
  8. yellow75
    Tillamook Oregon
    Okay I see now, I guess the search is on then. Around my neck of the woods you can get a nine inch that will fit for $350.00 but it would not be a posi (careful using that word here as that is Chevy terminalogy) :)
    Then you would have to buy the center section for say another $500.00 or less used, I am sure if you search you will be able to find what you are looking for at a decent price but just prepaing you for what expenses could be, sorta makes that 8 incher not so expensive at $750.00
  9. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    haha my bad lol my buddy has the center section for a 9 inch already, we would just need the gears and such so from what hes said i should be able to do everything under $400 from where im at...just gotta find an axle first!
  10. yellow75
    Tillamook Oregon
    My bad also I assumed you needed everything, well there you go the search is on.
    BTW I like your car I remember seeing it for sale a while back :thumbs2:
  11. ZaksComet
    ZaksComet Member
    Cleveland, Ohio
    1972 Mercury Comet
    Thanks! I got lucky that the guy who orignally posted pics of it on here had to take is down payment back because we had some strong storms here that did damage to his house. i didnt see his posts til a few weeks after i bought the car 2 days after he backed out lol
  12. Bryant
    one of the members sell a direct fit 9" housing for our maverick (dont rember his name). with his housing you can use your 8" axles and brakes if they are 5 lug. then all you have to do is make sure your limited slip is 28 spline not 31 spline.
  13. CaptainComet
    If you get an axle that is closer to 58" overall width, you can fit more tire out back with wheels that are still close to a factory offset ... keep the period look of the car without the tires being so close to the springs. Also, many Ford cars use the same width between spring perches, so you may luck out there.
  14. 71gold
    exactly what are you looking for...
    ...:huh:...
  15. Streamliner
    Streamliner Member
    I put 3:80's and a new Traction Lock in my 8" for about $550.00....Lighter than the 9" too
