accel coil
Discussion in 'Technical' started by Payette 302MAV, Sep 15, 2011.
  1. Payette 302MAV
    Payette 302MAV Member
    Payette Idaho
    1970 Maverick 302 painted Bahama Blue Metallic.
    any one out there running one of these pro stock accel coils??? i tried one a couple days ago and had bad problems with mine. it would over heat and not fire. my stock one wouldnt do that at all and i mounted both of them in the same place. im running a petronix setup with accel 8mm wires and wanted to get a better coil to open my spark gap.
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I went through 2 accel coils in a 6 month span once, one was the yellow and the other a crome one both were the can style... they had a problem of leaking at the top, I would pull off the main plug wire and see oil/liqued in the hole... come to think of it the car would just die on the highway and if I let it cool off for awhile I was able to start it again...
    the stock one never had the problem, I now have a Mallory coil in it now for the last 5 years with no problems.
  3. Bryant
    does the accel coil need a balast resistor?
  4. baddad457
    Could be you had the wrong type of coil for the Pertronix. Get one of their "Flamethrower" coils and it should be fine. Pertronix units use a stock type points coil. A coil intended for an electronic ignition (such as a Duraspark coil)won't function with it.
  5. mavgrab302
    Im using a msd blaster II coil with my pertronix, so far so good and .40 thou on the plugs...
  6. Payette 302MAV
    Payette Idaho
    david74maverick i had pretty much the same problem but went through two chrome ones in two days. it would over heat or something and quit working the P.O.S... ill probably just get a flamthrower for mine sometime....
  7. maverick75
    Been running the yellow one for 3 years now, works great.
    It's on a 200 running durspark. It's the first gen duraspark so i'm only running .036 gap on the plugs.
  8. David74maverick
    Arizona
    I was running my accel coils on a Mallory 6AL ignition module... I would assume that they may put out more spark than start but they may not be able to handle a aftermarket ignition.
  9. rthomas771
    My yellow coil lasted 4 years before it bit the dust. I replaced it with a $4 junkyard TFI coil off a mid 90’s Crown Vic. If you can run a full 12v coil with a Petronix this will be an option to look into. The TFI is 1-1/2 times hotter than the stock 'can' style coil. I since replace the junkyard coil with MSD name brand TFI. http://www.summitracing.com/parts/MSD-5527/
