Blowing Steam?
Discussion in 'Technical' started by Bioinfomatic, Jun 9, 2007.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    im guessing to remove the dash?
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    BINGO......When I was stripping my Maverick to make a drag car. I found it much faster and easier to get at the heater box by removal of the windshield.....this was an A/C car.
  3. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Smarter than me
    I was dumb enough to do my 88 5.0 Mustang. Boy, that was fun. And, since I'm not a very fast learner, I did it on my 85 Turbo Coupe. That one broke me of the habit. :cry:
    BTW, a sawsall was the tool of choice when I removed the heater and A/C box from my Mav drag car! (y)
  4. newtoford
    newtoford Member
    New Castle Delaware
    on a non- A/C car i removed the lower fiberglass part of the dash and glove box. from there it was all pretty straight foward. when my 88 town car started blowing steam i just ducktaped the upper vents closed so it didnt fog up my windshield and over power me with the smell of antifreez. no way i wanted to rip into that dash
    good luck
  5. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I did a heater core in a car over the winter that was in and out 4 times. Be careful of crappy workmanship and pressure test the core before you put it in. Nothing in life as deflating as putting in a heater core and filling the radiator and see coolant leaking from the passenger floorboard. Find out the recore was frozen in transit, after being pressure tested down south with straight water. Then next one was not soldered well, then the heater valve was not good, then the heater valve gasket was faulty.. oh yeah, I have lived heater core hell, anyone ever done a bandit edition Trans Am?
    Dan
  6. newtoford
    newtoford Member
    New Castle Delaware
    i know there definatly not fun on g-body gm's. the heater box is under the hood on the fire wall in a fiberglass box with the lid glued on. so there really is no way to get it apart without cracking it atleast once. not to mention taking half the windshield trim off olong the bottom of it. i assume 2nd gen f-bodies are pretty simular?
  7. hotrod-daddy
    hotrod-daddy Member
    I use to have '79 Trans Am with a 6.6 engine......I had to change the heater motor. That was no picnic.....I could just imagine what the heater core was like.
  8. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I've just got around to starting the heater core replacement, but I don't know where to start at.
    It seems simple because I don't have any A/C, Would I start by removing the four bolts on the fire wall that are under the hood?
  9. newtoford
    newtoford Member
    New Castle Delaware
    you need to remove the lower dash to expose the header box right behing the glove box. the heater core sits right in that black fiberglass box
  10. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I can't figure out how to open that box, or remove the lower dash.
  11. newtoford
    newtoford Member
    New Castle Delaware
    there are screws along the top of the lower dash holding it to the upper steel dash
  12. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Well once thats done how do I remove the heater core box, it doesn't seem bolted to anything?
  13. newtoford
    newtoford Member
    New Castle Delaware
    you dont need to take the whole box out. the front clips on and can be removed. once you take it off the core's looking right at you
    if ou have nice carpet keep in mind that you'll probably be spilling some antifreez...
  14. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Wow thats weird because I removed the the inter part of the glove box, and removed the clamps on the heater box but I can't open it. :mad:
  15. newtoford
    newtoford Member
    New Castle Delaware
    did you get all the clips? might be some sealer holding it too
