brakes problem
Discussion in 'General Maverick/Comet' started by Jims maverick, Jan 3, 2015.
  1. Jims maverick
    Jims maverick Member
    1970 ford maverick 3.3 liter
    So I rebuilt the front drum brakes because the wheel cylinders were leaking then I put fluid in and pumped the brakes a bit and the brakes engage but wont disengage could it be a bad master cylinder? My master cylinder is looking pretty rusty
  2. 71gold
    :Welcome:...:Handshake:
    did you replace the rubber lines?
  3. Jims maverick
    Going to the wheel cylinder? No they didn't feel spongy?
  4. 71gold
    some times after aging they break down on the inside and will stop up the line either braking or releasing.
    you could try opening the bleeder valve and see if they release.
    rthomas771 likes this.
  5. rthomas771
    Been there...done that
  6. mojo
    I wud replace the "rusty ms cyl". and the rubber lines. Wud'nt take a chance on either failing since they're both questionable from a safety perspective.
  7. Jims maverick
    I'm gona replace both but if I open the bleeder valve and it releases does that mean it was probably the lines?
  8. mojo
    I wud'nt bother w/ opening the bleeder until I replace the above mentioned parts. Since the master is questionable that way, U will only have to bleed sys once. I personally, believe a new "not rebuilt/reman." master. I believe the chances are less in getting a defective unit ---JMO.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    New return springs?
  10. rthomas771
    Open the bleeder half turn and listen. Get ready to hear it spit back. Close the bleeder and see if the brake let go. If they let go then you have a bad brake hose.
  11. Jims maverick
    So I put a new master cylinder in and new rubber brake line the brakes work but they take a min to actually stop the car is it just cuz my self adjusters need to adjust themselves and it will start to feel better after a while?
  12. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    When you put the new shoes on did you adjust the shoes to have a slight drag on the drum? The self adjusters are there to help keep the shoes in adjustment, not adjust it to where it needs to be.
  13. rthomas771
    You have to initially adjust the shoes when replaced to get the self-adjuster to adjust. See http://1bad6t.com/Maverick/repair/brake_system_02.html#f I have seen many of times the adjuster being on the wrong side of the car and they turn the adjuster the wrong way and loosen the shoes. This is why its a good ideal to change shoes one side at a time to prevent parts getting mixed together
  14. 71gold
    have you ever driven a drum/drum brake car before?
    could be there is still air in the lines.
  15. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Do the front Brakes have self adjusters?
