Dash pot
Discussion in 'Technical' started by blugene, Dec 6, 2010.
  1. blugene
    I know what they are individualy :rolleyes:.. What and where is it on a 250? carter YF.. What is it for?
  2. Acornridgeman
    Wisconsin
    Basically, what it does is stop the throttle plate from slamming shut. Best use is with a manual transmission. It makes shifting smoother with less engine surge. When you let off the gas to push in the clutch to shift gears, the engine RPM stays up for a second to make the shift smoother. They are used on automatics too.
    Often called an "anti-stall dashpot", they keep the engine from getting fuel starved and stalling by holding the plates open for a bit before returning to closed idle position.
    Not all carbs have them.
  3. blugene
    Intresting.. Where would it be?
  4. Acornridgeman
    Wisconsin
    You can see one (kinda) on this Carter YF - right above the linkage.
  5. john T
    john T Member
    coalinga CA
    72 maverick grabber
    cool this post made me realize whats wrong with the chevy luv im driving (apart from it being a chevy, and apart from it being a luv)
  6. blugene
    Thanks. I bet I don't have one. I was reading the thread where we were discussing the different carbs as I will be rebuilding mine soon. I shoulda jumped on that $50 one back then.
  7. maverick75
    My stock 2barrel had one. Never understood what it was, until now.
  8. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    Your Chevy Luv also has a idle solenoid, make sure it is working and somebody didn't just jack up the idle to pull from the venturis.
    sorry for the small hijack.
  9. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    yea if your an auto you wont need one, helps out on a standard and allows you to run a lower idle speed and helps between shifts like mentioned above
