Easy T5 swap use full mustang trans , keep mechanical clutch , no parts to buy !!
Discussion in 'Technical' started by towrecker, Aug 26, 2015.
  1. towrecker
    towrecker Member
    1974 comet gt 1 owner
    ok well it seems I have found the easy no fancy new parts way to do this swap 25 years ago , all I see is people talking about using special bellhousings , or converting to a cable clutch , or some kind of hyd clutch set up , I did the swap by using nothing more than the complete trans and bellhousing from a 1990 mustang gt , my clutch is 100% still manual linkage , and yes my clutch fork has to be pushed to the front of the car 100% backwards of the original setup in the comet , it is so easy to remedy this issue , I patented the fix also , but if someone is looking to do the swap on a budget , and has a saw , drill , and some scrap setting around , I will give you the idea of how to do it for free , being I have never mass produced this set up and offered it for sale , this will be if you PM me , and ask nicely , it is not hard to do or build , the only hard part is adjustment , you have to think about it , and field test your adjustments in the setup , there is no set adjustment parameters due to different setups among the donor transmissions , clutch selection , wear in your factory linkage ect , it can make a huge difference , but all in all it is not hard , like I said being I have never seen anyone ever go about this the way I have done it several times , and the fact it is easy , almost free , and it works great , I am willing to help you get the swap done , I am also curious to see what you build based on my idea , seeing you get it done , and seeing how you built it is my payment , so I guess the couple pics you might send me could be considered payment , so we will say the bit of battery power , and your time to take them , ok it will cost you 33.3 cents ;)
  2. mav1970
    That will help out a few members I'm sure :1st:
  3. towrecker
    towrecker Member
    since we have been working on this car restoring it , everyone has been so amazed by it , and all say they have never seen such a thing , so I did some digging , it looks like I am the only one to ever do it any way shape or form LOL so I thought I would share it ...
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Post that patent number, I'd like to look it up...
    Bryant, Static and Rasit like this.
  5. Bryant
    if you have a stick shift maverick already its simple to do the swap. you just need to take the t5 bellhousing and put the clutch fork pivot from the 3 speed maverick into the t5 bellhousing. it will need some adjustment to get the geometry correct but its simple and effective.
  6. rthomas771
    A one inch thick spacer placed one inch from the fork opening is all that is needed. I used a McLeod Clutch Fork...part number 16934 or you can use Ford part number C8oz7515A
    [​IMG] [​IMG] [​IMG]
    mvw66gt, maveruss1 and Bryant like this.
  7. JJ924
    JJ924 Member
    1973 Maverick
    I just bought a '73 Maverick with the 6-cyc motor and an automatic tranny. I really want to swap out the motor with a V8 but donor parts seem hard to come by. What are your thoughts on an automatic?
  8. bmcdaniel
    I'm using an old bell and the mechanical linkage. Just had to buy an adaptor to mate the T5 to the bell.
  9. 464925
    In my Mav.
    Maverick 1973-Pure Muscle.
    Hi! I know this post is old. I have a 302 4 speed. So if i bought the trans, the bellhousing, the pilot bearing and the square 1"x1"x2", and a transmission support Dont need anymore? Cut ThE shaft? buy a new starter? Thanks.
  10. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    That's a pretty ingenious solution, I like it.
  11. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
  13. 464925
    In my Mav.
    Don't know how this clutch fork works, mine is like this
  14. 464925
    In my Mav.
  15. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    That clutch fork is for an older truck or car (pre-60).
