Floor Pan Sheet Metal
Discussion in 'General Maverick/Comet' started by themailman19, Jul 6, 2021.
Tags:
  1. themailman19
    themailman19 Member
    Orange County
    1977 2 Door Ford Maverick 250
    hey all, i pulled the carpet and lining from the floor of my 77 mav and discovered some rust holes. as far as i know, the procedure for this is to grind the surface rust off and see what i can’t save, cut that out, and weld new sheet metal on there. most of it seems to be in the area where your feet would go, in the two front seat floor pans…
    go easy on me, i have no experience doing this kind of thing. I’m wondering what gauge sheet metal i need, and where to get it. or, if there’s an easier way to solve this problem, i am all for it. thanks :)
  2. yellow75
    Tillamook Oregon
    Floor pans are available, here is a link that tells you how to get them, I would imagine they make them for 77 as well . I would pour a bucket of water down the cowl (area in front of windshield ) and see if it makes your floor wet, common problem with Maverick or old windshield rubber
    http://mmb.maverick.to/threads/1970-maverick-floor-pans.122808/
    themailman19 likes this.
  3. themailman19
    themailman19 Member
    Orange County
    that’s a great resource, but i was thinking more along the lines of patching the existing pan, i just don’t know what kind of metal I’d need to patch it.
  4. themailman19
    themailman19 Member
    Orange County
    and thanks, i will definitely check out the seal on the windshield.
  5. Powerband
    Powerband Member
    NY's \H/
    ... good suggestion on checking cowl area for source of rusted floors.
    Typically, 'floor panels' - pieces of the floor steel are available with similar shapes making fab/fix easier. Although specific Maverick pieces my not be available, similar earlier Falcon or Mustang can be used. Mustang vendors are a good source and have good illustrations.
    https://www.npdlink.com/1965-1973-m...y-parts-and-sheet-metal/floor-pans-extensions
    And of course any old steel panel can work depending on your resources and abilities. Mild steel sheets in 18 to 22 gauge are readily available from steel shop or interweb.
    https://www.ebay.com/sch/i.html?_fr..._sacat=0&LH_TitleDesc=0&_odkw=ramsa&_osacat=0
    you can also simply use old steel panels cut from hoods and other spares for new fabbn'
  6. mojo
  7. 71gold
    as suggested before...find out why the pans rusted before doing any repair. If it's the cowl leaking that is a whole nother ball game. about a $2,500 project if you have to pay someone to do it. that is if you can find someone that will/can do it.
    try not to get any water on the windshield when you go to check the cowl. that way if the cowl isn't leaking you can then pour some water on the windshield to see if it's the glass seal.
    mojo likes this.
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    If you’d like to get the correct floor panels for your car follow Mojo’s advice and contact
    3PG (Period Perfect Parts Group) by sending a email to Patti Harper-Diotte at patti10@aol.com Send her your name, shipping address, phone number, year make model of your car, the parts you need, and photos of damaged areas.
    She will get you fixed up with the parts to do the repairs:thumbs2:
    mojo likes this.
  9. bmcdaniel
    I used 16 gauge galvanealed steel.
