floorshifter
Discussion in 'General Maverick/Comet' started by bobtackett, Jul 22, 2003.
  1. bobtackett
    bobtackett Member
    chicago heights ill
    1971 mav 302 4bbl headers
  2. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    I second that as a yes.
    -Todd;)
  3. bobtackett
    bobtackett Member
    chicago heights ill
    great
    :) :D :D :D i can hit the bid button than right guys.now all i need to do is find the linkage for it.thanx
  4. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    If you can find linkage, let me know. Im putting mine in relatively soon.
    -Todd
  5. perceptionist
    perceptionist 1973 4dr Mav 302
    San Diego CA
    1973 4dr
    Linkage
    I am now in the process of hooking up a floor shifter I pulled from either a pinto or comet, mounted it 2 yrs ago and just now getting around to linking it up:) Found the linkage from a pinto to work beautifully. Have a picture of the linkage out if you are interested.
    mm
  6. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    That would be great if you could post a pic of the linkage. thanks
    -Todd:)
  7. perceptionist
    San Diego CA
    1973 4dr
    Linkage pics
    I neglected to make note of the year Pinto this linkage came from:( sorry,
    Hope I attached the pic correctly,:rolleyes: if not, email me and will send a couple
    perceptionist@yahoo.com
    mm
  8. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Awesome! now i know what to look for at the junkyards! thanks a bunch!
    -Todd:)
  9. perceptionist
    San Diego CA
    1973 4dr
    Glad I could help!:) I will say that when I mounted my floor shifter 2 years ago, I had no clue what kind of linkage to use or where on the hump to mount the shifter so I guestimated. I have learned that I mounted it about an inch to far forward for my pinto linkage to be usefull, however a machinist friend can cut the linkage bar and put a threaded collar (similar to the one connecting the inner/outer tie rods) for ease of adjustment:D
  10. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Where is the proper place to put the hump?
    -Todd:)
  11. bobtackett
    bobtackett Member
    chicago heights ill
    where to mount
    when i had my 1st maverick we did the same thing.if you pull the carpet up there should be, not so much a knockout plate, but an outline where the floorshiftrer belongs.remember these cars did come from the factory with floorshifters.I just could not remember what i got my shifter out of.20 years is a long time ago.
  12. perceptionist
    San Diego CA
    1973 4dr
    Floor shifter mounting
    Mine did not have these marks, If I was to do it again, I would find the pinto linkage and use that as a guide for mounting the floorshifter.
    Try the following links to previous posts here:
    http://www.maverick.to/mmb/showthread.php?s=&threadid=455&highlight=floor+shifter
    http://www.maverick.to/mmb/showthread.php?s=&threadid=205&highlight=floor+shifter
    And this one is excellent, helped me out a lot...
    http://www.maverick.to/mmb/showthread.php?s=&threadid=2563&highlight=shifter+position
  13. perceptionist
    San Diego CA
    1973 4dr
    Oh well, I tried clicking these but they didn't seem to work. Just search all forums keyword floorshifter or floor shifter, some good stuff.
  14. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    My '73 had the outline where the floor shifter goes. Was a piece of cake. Not sure about 4-doors but can't imagine they're any different. To make it all work, you need the shifter shaft that mounts to the transmission, you have to drop the pan and valve body to remove and install it. All late '60s and early '70s Ford floor-shifters will work. Pintos, Mavericks, Mustangs, Torinos, Granadas, Mustang-IIs, etc...
