Fuel Filler tubes
Discussion in 'Technical' started by Grabber71, May 11, 2008.
  1. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    Are the Fuel filler tubes different betweent the years? I tried putting one I had from a '71 Maverick into a '76 Comet and it only seems to go into the tank so far and binds. I realize that the holes to mount them are different and that the later ones only accept the small filler nozzles...but is the bend different? I have to go about another half inch..and it don't seem to go..
  2. PaulS
    Well, the tanks are different but I think the filler is in the same location.
  3. Craig Selvey
    What you are doing should work. Try a little vaseline or oil on the neck before you shove it in the tank.
