Fuse panel on a 75 6 cyl 250
Discussion in 'General Maverick/Comet' started by caseman97, Jun 19, 2009.
  1. caseman97
    caseman97 Member
    London Canada
    74 4 door 6 cyl.
    Could anyone steer me in the right direction on where the fuse box is on my 75 250 6 cyl. I cant find it and dont have a owner or shop manual .. Have no dome lights or front side markers... Do those front side markers work as side signals ??:rolleyes:
  2. rthomas771
    Dome light and side markers are on a different circuit. Fuse box is on the firewall...very top-left side
  3. caseman97
    caseman97 Member
    London Canada
    74 4 door 6 cyl.
    Thanx , good stuff..
  4. caseman97
    caseman97 Member
    London Canada
    74 4 door 6 cyl.
    :cry:OK , I just found the fuse panel , removed screw with spring , courtesy light fuse blown, moved fuse box down around brake pedal to remove fuse,
    No power now to nothing att all..
    Is this screw with spring a ground wire ?? What the heck have I done ??:cry:
  5. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    You won't get power to anything until you re-install the fuse box. That's grand-central station for power in your car. Hope you disconnected the battery negative terminal first, because you just pulled the main disconnect with live hot wires when you separated the bulkhead connector. Never know what you might fry, including yourself on the two fuse holders that are always hot. Specifically, the bolt holds the two halves of the bulkhead connector together, plus the fusebox since it is attached to the inside half. Power from the battery goes through there to the ignition switch, and all power in and out of the engine compartment goes through that connector (with a couple minor exceptions).
  6. caseman97
    caseman97 Member
    London Canada
    74 4 door 6 cyl.
    Thanx , yes I discon battery , what a production to rehook panel.. Wont be doin that agian.. Thanx for help , all lights , dome , trunk , glovebox , maps , underhood working , cleaning grounds today..:cool:
