It's Gone!
Discussion in 'Technical' started by dmhines, Nov 13, 2004.
  1. Ronn
    Ronn Member
    darnit,noticed your banner :slap: guess were still cool though! :D :cool:
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Round two today ... the most exhausting part of the job was removing the four bolts on the front bumper frame mounts ...I'm glad the first one turned out to be the hardest because it was a beetch! Got the spoiler mounted as well ... I've decided to notch the front gravel guard instead of hacking up a perfectly good set of fenders.
  3. Mavaholic
    What method are you going to use to attach the front brackets?
  4. dmhines
    Cumming, GA
    Not 100% sure yet about the brackets. I will either drill all the way through the frame and bolt them that way or use the Dan Starnes method and only drill the outside and make a slot for the head of the bolt and slip it into the frame and then tighten it down.
  5. 71gold
    dan,
    you could use the stovebolt type like are on the gas tank straps (y) ...frank...
  6. dmhines
    Cumming, GA
    Good idea Frank ... I could dremel a slot similar to gas tank slot as well. I'll have to see what size bolts ACE Hardware has of that type. Is it a stove bolt or a carriage bolt - sort of like bumper bolts with the square flange below the rounded head.
  7. rayzorsharp
    Lookin good Dan...keep up the good work.
  8. dmhines
    Cumming, GA
    Dennis ... you did say you have used the 67/68 Mustang rear inner trunk bumper brackets and they worked? The reason I ask is that they look the same in pictures but the Ford Parts book does show the Mavericks as having a different number. Green wants $30 each for the Maverick NOS brackets and the repop Mustang brackets are only $15 .... Thanks ... I'll probably pick up a set of Mustang brackets at Moultrie if you can confirm they work .... Dan
  9. Mavaholic
    Thats what I used. Worked great.
  10. dmhines
    Cumming, GA
    Cool ... THanks ...
  11. dmhines
    Cumming, GA
    Worked on the front today ... couldn't find my Dremel cut off blades so I didn't install the gravel pan. The front bumper looks like a pretzel ... it's coming off later today to use as a core for a new one at the Moultrie swap meet this weekend. I hope they take it .... :)
    Edit: Oh ... Forgot I had some Grabber Bezels ....
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    That looks SO much better than the big bumper. WTG!
  13. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Looking good
    Thats Looking great Dan. Are you going to paint the valances yourself?
    Later Tim
  14. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Looks good Dan. BTW, Dan I found a set of Grabber bezels in the junk yard and the black needs to be repainted what kind of black would you sugest I use?
  15. dmhines
    Cumming, GA
    Yeah ... I'm gonna smooth and spray bomb the valances and rear spoiler myself. Gotta do the sport mirrors too ... Someday I'll got the hole car repainted but for now it's just gonna be a nice driver .... For the folks that say they like the big bumpers ... to each their own I guess ....
    And without the big bumpers even the side moldings are starting to look good!
