Looking at replacing to a 9" rear
Discussion in 'Drag Racing' started by pil1sbury, Feb 16, 2016.
  1. pil1sbury
    pil1sbury MavBoy living life
    Virginia
    1974 FORD MAVERICK
    Ive been looking at replacing my 8" rear for a 9" rear. I've put some posts on some of my local fb pages for a 9" rear but idk if I want to buy a used or new rear. I've talked to a few shops and I've looked at quick performance and moser.
    So what's y'alls experience with this and what did you end up going with. IMG_20151213_182029.jpg
  2. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    I went with Quick Performance.
  3. Hotrock
    Munroe Falls, Ohio
    Why do you want to invest in a 9" differential?
  4. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    The engine I had built makes too much power for the 8 inch. I needed the 31 spline axle shafts and I wanted trac lok and bigger brakes.
  5. Mavric65
    Mavric65 Member
    Sacramento California
    1973 Maverick
    I have been looking at Quick Performance also .... HarleyGA did you get it made to stock width or did you get the 65 mustang width which is 3/4 of a inch wider ... it works out to 3/8 of a inch on each side and thought I wouldn`t have to run spacers behind the wheel.
  6. Mavric65
    Mavric65 Member
    1973 Maverick
    In my last maverick I broke two 8 inches both times snapped a axel and ring and pinion... very expensive wish I would have just spent the money on a 9 inch it would have saved me money in the long run
    bossmav likes this.
  7. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Here is what I ordered.
    $680 - 9" Housing/Axle Package (1973 Ford Maverick)
    - Big Ford (Old-Style) Housing Ends
    - 51-1/4" Housing
    - 43" Center to Center on Perches
    - New Axles, Axle Bearings, Wheel Studs, & Retainers
    - 31 Spline, 5 on 4-1/2" Bolt Pattern, 1/2" Studs
    $820 - Center Section (Assembled)
    - New 31 Spline Trac-Lock Posi
    - New Motive Performance Gears (3.70 Ratio)
    - New Timken USA Bearings
    $300 - 11" Drum Brake Kit (New Drums, New Shoes, & New Internals)
  8. Mavric65
    Mavric65 Member
    1973 Maverick
    Thanks for the info
  9. pil1sbury
    Virginia
    1974 FORD MAVERICK
    I want to do the swap because I'm gonna mini tub the car, so I'm moving the leaf springs and I figured I'll just put a strong rear end. The car is gonna be a street/strip car 10" wide tire with either 3.60,3.70,3.89, I don't think it's gonna happen but 4.10
  10. Rudydog
    Rudydog Member
    1973 Comet
    I did the whole Quick Perf. 9" deal, went with 35 spline Moser axles w\ Strange ctr. section. And the Youkon Grizzley locker. Very happy with it. What you get is a cut down truck rear I believe, and they put new tubes and ends on it. I went with the same ends as my 8" so I could use the stock rear drums, just hung them up for the install, didn't even have to bleed them. On a side note, because of the bigger tubes, it lowered my Comet a little..
    pil1sbury likes this.
  11. Streetnstrip
    Streetnstrip Member
    Fletcher NC
    70 maverick
    I used quick performance on my race car years ago & was pleased with the products from them
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What did you use for driveshaft?
  13. aussie maverick
    aussie maverick Member
    queensland australia
    1973 maverick ex ed davis
    Due to limited resourced for Mavericks over here, I recently gave my 8inch housing and a 9inch housing to a guy, he built a housing using the 8inch tubes, cut to length 31 spline axles, 1/2 inch studs @$650. I then purchased a Yukon locker, Richmond light weight and polished 3.89 gearset, and strange centre section. Total cost back in my car was just under $2000. I'm happy with that as was quoted $3500-4000 to have one built
  14. Rudydog
    Rudydog Member
    1973 Comet
    I'm still running the stock driveshaft. Had to switch up the u-joint though.
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No difference in length?
