maverick in front too high,need help!!
Discussion in 'Technical' started by lynhrt210, Nov 21, 2009.
  1. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    ok so i got a 74 maverick and my broinlaw has a 71 grabber i parked mine next to his and i noticed that my front end is higher than his,was wondering if anybody can tell me whats up with that or any hints on how to get it lowered down thanks!!!:thumbs2:
  2. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    well you can cut small sections out of the spring or search "Shelby Drop" on the site (y) i'm no expert on it but i'm sure somebody will know how much to cut
    is this by chance your brother inlaws grabber?
  3. Jeff S
    Jeff S Member
    NoVA
    none
    mean_maverick cut a coil out of his and it dropped the front by 2"-2 1/2" but it all depends on spring wear and the weight of the front end, you might want to ask him the best way of doing it since he did his within the last month(or maybe he'll comment here)
  4. bmcdaniel
    Fat chick in the front seat....
    NM
  5. justin has a 74
    kentucky
    Heat up the coils
  6. maverick75
    Dont ever do this.
  7. rthomas771
    Shelby drop will not have any effect on ride height.
    Never ever put heat to a spring
  8. justin has a 74
    kentucky
    :ignore: ......
  9. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Raise the rear end up until you have the desired rake.
  10. JHodges
    JHodges thumper
    Dora Alabama
    maybe your brother in law has wore out springs
  11. maverickdragger
    maverickdragger GearHead
    Oneonta, AL
    1973 Maverick
    your brother in laws car was prolly a factory 6 cylinder. the springs are weaker and set lower.
    i put the blue wrench to mine. it aligned my front end lowered it and took out the bump steer and tire wear.
  12. Jeff S
    Jeff S Member
    NoVA
    none
    Yeah dont heat them, it weakens and stiffens the spring considerably at all heat points, Im sure the last thing you want is to hit a bump and end up with 3 or 4 mini-coil springs on one side...lol
  13. Blown 5.0
    MS.
    1974 Maverick
    A Blower is usually heavy enough to drop it some.
  14. Fish OutOfWater
    Fish OutOfWater Brian
    Long Island, NY
    You had two Mavericks side by side? Thats a mini-meet! where's the pictuers?
  15. Rick
    Rick G8I operations
    Ocala, Florida
    That would do it or a 351w. I did 351w and cut the coils.
