More project pics
Discussion in 'General Maverick/Comet' started by Racer_X, Jan 27, 2011.
  1. PaulS
    Using a cartridge type fuse of 200 amps is pretty much the way to go if you are running an alternator with more than 100 amp rating. You should also run at least 2 awg cable to the alternator Battery terminal (1/0 if the battery is in the trunk).
  2. Awesome_X
    Awesome_X Member
    Oklahoma
    I see this sounds like a good upgrade from the duraspark box, I may be asking about this set up in the future.
  3. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    alot of jeep owners use the set up im using wth no issues. i payed a quite a bit for the accel brand module but it was better than getting a chinese one. google gm hei module and youll find all the info u need
  4. Bryant
    looking really nice.
    whats going on with the throttle cable in the first pic?
  5. Racer_X
    North Carolina
    i had to cut the cable to legnth and at one point i cut it too short and then the worm screw striped out so i had to drill it out and put that screw in it.
  6. mojo
    Thanks for the info - RaceX. I read those articles and thinking of trying it sometime in the future.
  7. Racer_X
    North Carolina
    no prob, glad to help
