Need help with hydraulic clutch!!!
Discussion in 'Transmissions' started by bradmaverick, Dec 9, 2015.
  1. bradmaverick
    bradmaverick Member
    maverick 71
    This hydraulic clutch setup is strange I can't find anything like it.
    The bearing that goes on there is s-1248 510 I can't find this bearing anywhere.
    Please help if you know what this is
  2. Dave B
    Looks like it might be a Mcleod hydraulic throw out bearing.
  3. dyent
    dyent Member
    vancouver bc
  4. baddad457
    Looks similar to the Mc Cleod unit I have (which is about 15 years old now) but has a longer body. It has different hydraulic fittings too. Mine came with swiveling banjo fittings that leaked right off the bat. I changed them to AN style fittings that do not swivel, making it harder to install the unit, but there's zero leaks since then. Your's might be a newer McCleod unit, could be that as they changed the fittings to AN style right after I bought mine.
