No Lights on Dash Board and Instruments
Discussion in 'Technical' started by miguelgarriga, Jan 23, 2006.
  1. miguelgarriga
    miguelgarriga New Member
    Puerto Rico
    1972 6 Cil. Maverick 200 Motor
    Hello
    I have a 72 6 Cil. Automatic with 200 motor. Dash lights wor working fine until yesterday. We were trying to install a new Radio with CD player. It seems like the new radio was drawing too much power. After that all the lights on the dash board are not working. The head lights, signals, and stop lights are OK. I checked to see if there was a blown fuse. I install the original radio and is working fine. However no lights on the interior.
    Help please.
    Thanks
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    make sure you didnt accidentally nock one of the bulbs out or the wiring harness plug:huh:
  3. miguelgarriga
    Puerto Rico
    No Lights on the Dash
    Where are the lights located on the wiring harness. Is there a relay which might get shorted.
    Thanks for replying
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    It's the fuse...
  5. miguelgarriga
    Puerto Rico
    I checked all the fuses on fuse box and all seem fine. Can you tell me which one exactly controls the dash lights.
    Thank you
  6. MikeG747
    MikeG747 Member
    Arkansas
    It is the smallest fuse in the box. It is on the bottom row.
  7. T.L.
    T.L. Banned
    Southern Colorado
    How did you "check" them? ...
  8. miguelgarriga
    Puerto Rico
    It was the fuse!!
    Lesson learned! I pulled it out and did a continuity test. It was the fuse. I got lights now.
    Thank you... Thank You ... Thank You again from Puerto Rico.
  9. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Welcome to the board.
  10. T.L.
    T.L. Banned
    Southern Colorado
    Yeah, you can usually see when it's blown, but not always. Glad you figured it out...
  11. Jamie Miles
    Alto, GA
    I've had a few
    Cool, maybe thats my problem. My dash lights also quit working a couple of days ago. I figgured it was the headlight switch going bad. I'll check the fuses tomarrow!
  12. jgranata63
    jgranata63 New Member
    conn.
    1972 maverick grabber
    Im having trouble trying to get reverse lights working on a 72 maverick switch on 3 speed trany works lights work when jumped out,but do not work normally
  13. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Glad to see another member from Conn. Maybe we can get all the Conn. members together some time.
  14. jgranata63
    conn.
    thanks, i would like to see your maverick, as soon as i can figure out how to post some pictures i will, just installed fuel tank, what a job, when they say its going to be a tight fit there not liying, especially with dual eghaust.
