Non remote Driver sport mirror? modifications?
Discussion in 'Technical' started by fuelish351, Feb 23, 2015.
  1. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    Has anybody here converted their remote driver sport mirror to a manual one. I am really not a fan of the remote function and the knob has been broken since I got the car. So today I was going to take out the cable so I removed the mirror and cut the cable, now its all floppy :(
    I will probably make abracket to mount the passenger side mechanism to the driver side, just want to see if anybody has done it before and how
  2. 71gold
    how do you know you're not a fan if you have never used it...:huh:
    Crazy Larry likes this.
  3. Rasit
    Rasit Member
    SE Pennsylvania
    Yikes, a mirror molester! You might as well position it where you want it and fill it up with that crazy spray foam insulation. :)
  4. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Reproduction replacement knobs are made for the remote mirror...
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Why not remove the mirror assembly from the housing and do what you can to " tighten" the ball assembly where you can adjust it but the flop is diminished ? Seems logical .
    Cometized
    ( Chip )
  6. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Ive thought about this as well. It seems that the passenger mirror should be the remote one as the driver mirror could easily be adjusted by rolling the window down.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I think it was either Pinto or Mustang II passenger mirrors that had about a 6 foot cable to mount the knob close to the driver.
    NCFatBoy likes this.
  8. ammenraa
    ammenraa 1972 Maverick Grabber. 302 V8 T-5 WC 5 speed
    Kabul, Afghanistan
    1972 Grabber
    How does one "tighten" the ball assembly so the glass isn't floppy??
  9. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    One can not tighten the ball assembly. The cables hold tension on a spring and seat connected to the mirror backing. One would have to engineer something to hold it in place and have it be adjustable. It is not at all designed like the passenger side.
  10. ammenraa
    Kabul, Afghanistan
    1972 Grabber
    I was meaning the passenger side.
  11. Fordmaster169
    Coos Bay, Oregon
    You can only access the ball tensioner on the passenger side if the mirror glass is removed. Then you can get to the 2 screws that hold the retaining plate in place. You would probably have to remove the plate and bend it back straight then re install it. Then get another mirror glass to replace the one you broke trying to get it out of the mount.
  12. ammenraa
    Kabul, Afghanistan
    1972 Grabber
    Ahhhh. I never considered breaking the glass off.
  13. rthomas771
    yellow75 and NCFatBoy like this.
  14. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    I stand corrected .. with all you ' mirror-masters ' !
    Cometized
    (Chip )
  15. ammenraa
    Kabul, Afghanistan
    1972 Grabber
    Shit. I was hoping you could tighten the ball assembly to be honest.
