Pertronics Ignition question
Discussion in 'Technical' started by Positively Ralf, Oct 25, 2009.
  1. Positively Ralf
    Yonkers, NY
    1974 Maverick
    what are the differences in gains between this setup and the Duraspark setups?
    And btw, is this igntion only available through their online shop?
  2. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    You can pick it up anywhere. Try Summit.
  3. Bryant
    both systems will give you good perfomance. the pertronics is compact and doesnt add anything out side the distrubor. the duraspark has a large external box that is not the prettyest thing. to goto the duraspark you need the box and dist. if you buy them new it may cost more than the pertronics.
  4. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Thanks for the replies. BTW, went to the pertronix site but they seem to carry a whole mess of different setups. Which would be the right one for a i6 200?
  5. Acornridgeman
    Wisconsin
    For the I-6 200 - just use the standard model Pertronix #1261 -- it is an outstanding value and very easy to install. It will work perfectly fine with a stock coil. For 1974 cars and older.
    :bouncy:
  6. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Be careful to use the coil they say to use with the Pertronics. Coils will burn out if not the right one.
    When going with pertronics you need to be sure that the old distributer is in good shape. One benefit with going with a rebuilt Dura-Spark is the rebuilt part of it. If your old distributer is worn out you will still have ignition based trouble.
    clint
  7. bmcdaniel
    There's a place on ePay that sells Pertronix really cheap. The instructions that come with it will tell you how to measure your coil to make sure the primary resistance is correct.
  8. scooper77515
    I don't think the choice of coil is really strict. It is not like you have to buy the pertronix then shop around for a special coil.
    I had an Accel Super Stock coil from O'Reilly's in the car to begin with, swapped points for Pertronix, and been fine ever since. THEN added MSD last week, and running even better now with .060 spark plug gaps!!! All on a stock replacement distributor from O'Reilly's.
  9. bmcdaniel
    The coil has to have a minimum resistance as stated in the Pertronix instructions or the module will overheat and die. IIRC, for the Ford V8 module the coil has to have 1.5 ohms primary resistance. Obviously this only matters if the module is directly switching the coil, if you're using the Pertronix to switch an ignition box the coil resistance doesn't matter.
  10. Positively Ralf
    Yonkers, NY
    1974 Maverick
  11. Acornridgeman
    Wisconsin
    Looks all stock - voltage regulator looks like a store brand replacement - but still all OEM specification stock stuff.
    :yup:
  12. Positively Ralf
    Yonkers, NY
    1974 Maverick
    But is it good ol points or good ol electronic? Cause the 74 Mavs, that stuff was optional.
    Cheers!
  13. maverick75
    Look at the area below the windshield washer reservoir if you see a box then its electronic. 0n the falcon we used the dizzy and module from a 74 mav with an accell super stock coil and its flawless. starts up better and no more adjusting the damn points. lt was only $25 using junkyard parts.
  14. 302-72-mav
    302-72-mav Member
    sactown CA
    take a few pics with the distributor cap off so we can see whats in there
