replaced my starter...
Discussion in 'Technical' started by random hero, Jan 24, 2010.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    now i have a really loud whine almost like a supercharger...anyway to quiet this down? is there something worng? is it a break in period? idk never replaced a starter before. 72 maverick 200 I6
  2. Dave B
    All the time, or just when it starts?
  3. random hero
    hudson valley
    1972 maverick
    just when it starts, like the gear on the starter is meshing to tightly with the ring gear
  4. Dave B
    Could be the wrong snout on the starter, did you compare the 2 when you swapped it?
  5. random hero
    hudson valley
    1972 maverick
    yes..they looked the same...whats the snout?
  6. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    Stick or auto?Not sure on the 6's,but the 302 starters have a different snout on the starter,depending on if it's for a stick or auto trans.Maybe the same goes for the 6's?:huh:
  7. Boosha
    Buckeye State
    The snout (or cone)is the front section of the starter that goes into the trans.Do You still have Your old starter.or used as a core?If You have it check the length of the orig.snout against the new one.
  8. random hero
    hudson valley
    1972 maverick
    would the snout make a difference just while starting though...they looked the same. when i replaced my flexplate, and put my starter back in it did the same thing. a friend of mine adjusted it somehow and it stopped making the noise. idk what he did...lol
  9. Boosha
    Buckeye State
    If it's a different length it could.Did You make sure the starter bolts are nice and snug?If there loose,even the slightest bit,it could also cause Your problem
  10. rthomas771
  11. 71gold
    does a 200 have a...motor plate...if so does your motor have one?
    ...:bouncy:...
  12. random hero
    hudson valley
    1972 maverick
    yes they do...and no mine doesn't...lol i noticed when i replaced my flexplate...but i figured since it was fine after whatever my friend did it would be fine...i'm guessin i need a plate...or atleast a shim. can i even get one for my car? the shim above wont fit my application.
  13. random hero
    hudson valley
    1972 maverick
    if i got a motor plate could i just cut the section out for the starter? i dont wanna have to pull my tranny out again :huh:
  14. 71gold
    the...motor plate...is the...starter shim...:slap:
    ...:drive:...
  15. rthomas771
    The motor plate also keeps the transmission input shaft from bottoming out on the crankshaft. You need the motor plate IF it had one originally.
