302 trans
Discussion in 'Technical' started by shaunh82, Sep 13, 2005.
  1. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    well, I think I'll go with the $60 jobber, the auto ain't stayin long :D
  2. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    what about the oild pan, am I right in thinking that a double sump pan will not clear the steering linkages or the cross member?
  3. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Yes you will need a front sump oil pan from an early 289 or a 302. You will need the timing cover , dip stick , the fuel pump cam from the front of the timing chain and if you are not gunna use headers you will also need the exhaust manifolds as well .
  4. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    right, I have a brand new ford racing timing cover, I'll probably get a flexible stainless dip stick, just so I don't run into problems, thanks for reminding me abou tthe cam, (used to efi), need a new timing set anyway, any recomendations? I still need to have my heads done, re gasket my carb, and such, just trying to make a mental note of what I need to order
  5. elliot
    elliot Member
    Boubon MO
    When I had to replace the timing chain in my mothers van I just got a cheap (15 bux) dual roller timing chain from the parts store.
    I don`t know how high in the rpms I`ve had the engin but I had the van up to 120 mph so it was reving purdy darn high ;) and no problems yet.
  6. Jamie Miles
    Changed your oil filter lately? :)
  7. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    LOL, it's a Fram on top of that!
    I used Fram filters for years without any problems until I started hearing all the bad stuff about them. I only run Motorcraft now.
    clint
  8. elliot
    elliot Member
    Boubon MO
    I changed the oil and filter after I replaced the timing chain and no I didn`t use a fram filter :p .
  9. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    haha speaking of oil filters... MOtorcraft does make a GMC filter for 88-2000 350.... I didnt want to put a cheapo, don't like delco filters, and will not run a fram. They make them... Thats the ONLY thing they fit. haha
    Anyways, hope you do well w/ your swap
  10. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    you guys running 302's with auto trannys, what is being used, or what can be done to a C4 to make it a halfway decent runner, I may keep the auto for quite a while, the manual swap is going to be a job and a half I think, may hold off for a while. What other trannys can I swap in to the car and maybe have o/d without too much work. I can physically have the engine in the car this week, and running in a few:drink:
    Thanks
    Shaun
  11. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    The easiest overdrive to put in wou.d be the AOD. No computor to worry about. Pretty easy installation that has been discussed quite a bit in other posts. Might want to do a search on it.
    The main things to watch for are getting the right balance flex plate and getting the TV cable set up right.
    clint
