well pulled the tranny and the converter has bout a quart of oil only I haven't drained it but it looks like a quart. Took the pump off again cause it had a small leak between the bell and the case and found out the pump to case gasket was broke,while I looked inside I noticed that there is like a loose lock maybe is it normal or is outta place but its not in front its like a little ways in the trans
