carb vs efi?
Discussion in 'Technical' started by JD71, Sep 29, 2007.
  1. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    I dont believe so.
    But hey be a pioneer and be the first. I havent heard of anybody putting a modular supercharger on a 302. I could be wrong look into it more.
  2. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i looked, it seems like it would be cheaper to buy the right one new than mod to fit the other
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    If I had it to do over again (without knowing what it took to overcome the electrical demons), I'd stick with a carb - especially if you're a novice mechanic.
    You'll have your car running a lot sooner and with a lot less headache sand a few more dollars in your wallet.
    (from the :2cents: department)
    Good luck.
  4. awannabegrabber
    Wichita, Kansas
    Get EFI and turbo it, and use your computer to run the computers or the Y band if you get one
    or get a Carb system turbo and slap a BorgWarner 75 Milimeter Turbo and run 25 lbs of boost all day long.
  5. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    ok, what does it mean to run the 35 lbs of boost all the time, as in would i be getting boost at idle? and what are all the pros and cons of the efi? and could i get some prefered brands so i can look up prices?
  6. awannabegrabber
    Wichita, Kansas
    Ok. 25 PSI all day means when you boost. like most turbos reach full boost at around 3 1/2 thousand rpms. it can boost 25 pounds easily. That might be a little hard on your block and internals. you dont get boost at an idle. the turbo might spool alittle but no pressure is built
    The EFI can be run through a computer that will adjust the F/A ratio at different RPMs.
    The carb will only let you run at 2 settings idle and boost. This is mainly for drag racing tho. So it will either run lean or rich. I watched a guy split his block trying to show off in a parking lot because he didnt have his settings tuned correctly.
    I would recomend the EFI. Get a good tune on it, and a blow through set up with an Inter Cooler, and a greddy Bov, with a y band, and boost controller.
    Brands to look at would be Greddy, TuroNetics, HKS, Apex, you dont have to get all one brand tho you could mix a custom manifold and piping with a commings tubo, a supra 650CFM I/C, and a Standard Y band and a tune and that would work perfect for you
    Here
    http://www.turboneticsinc.com/products/index.php
    For piping you can have an exhaust shop make you down pipes, manifolds, intake pipes, brackets...ext.
  7. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    well i think im gonna just stick to buildin my motor carberated until i get the money to buy a new supercharger to put on there. what about the innercooler, would one still help even without the charger
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Leave it off until you get everything else set up & together.
  9. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Anyone have the measurements for a mod motor & a 302 too compare? Will a new hood & cut out shock towers help a mod motor fit?
  10. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    i dont know much about it but im sure anything will help. i've seen where it has been done and the guy i was gonna get the supercharger from's cousin is putin the 360 stroker 01' roush/svt motor in a 64 1/2 mustang
  11. awannabegrabber
    Wichita, Kansas
    Here is a thought GET THAT ROUSH MOTOR AND SLAP IT IN THE MAV, then call it good
    The intercooler woulnt do much with out a supercharger or Turbo.
  12. Thack
    Thack vision advicator
    Moreno Valley Ca
    Here is the Kenny Bell web site I beleave that is a 5.0 on this list. Kenny Bell started with the 5.0 before the Mod motor was out........you may not be old enough to remember :D
    http://www.kennebell.net/superchargers/supercharger-selector.htm
  13. Dave B
    When I hear KenneBell, I still think of Buicks, they were the ones for Buick performance parts years ago.
  14. awannabegrabber
    Wichita, Kansas
    Well i remember looking on the kennebell web site and they didnt have that
    Good find. Well Theres a quality supercharger for ya(y)
    And yeah im only 18 but im always reading and looking for new info and ALWAYS ready to tear apart somthing and build it better.
  15. awannabegrabber
    Wichita, Kansas
    how long ago?? How B.A would a Supercharged Buick GS be??
