Fuel pump for a fuel injected 306 maverick???
Discussion in 'Technical' started by 89gtsleeper, Feb 17, 2007.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    JAMIE
    Here are some pic of my fuel system ( i.e. bulkhead fitting , AN fitting adapter , fuel filter , pump , pump adapter to double flair ,
    thx jay
    pic l to r
    bulkhead fitting pic 1&2
    AN fitting adaptors
    fram hp fuel filter
    fuel pump
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    here is more pic
    left to right
    pump to double flair custom
    made from these parts
    fittings on pump
  3. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    You just plug the return end of the rail.
    The fuel then circulates either around the pump, or you can dump it back into the tank if you want, or your secondary pump tank. It's less modification to your stock tank. A lot of newer fuel rails don't use return lines, but instead use a variable voltage pump to vary the pressure and thus the flow.
    The picture that I attached still uses a single voltage pump, but by mounting the FPR in a loop around the pump, you don't need return lines from the engine, and you also don't need to plum a retun line into your tank. Much more easier. Like I said, this is the way most of the common rail diesels get fuel to the engine. The diesel pumps are also external and much more quiet than your standard aeromotive pump. Might be worth looking into.
    It should also clean up the engine bay quite a bit.
