How did you break in your new engine?
Discussion in 'Technical' started by ESampson, Jan 15, 2012.
  1. olerodder
    olerodder Member
    NorCal
    So, what kind of rings are on the pistons?
    If you have moly rings............just break it in for the 20minutes to get the cam/lifters seat properly......................and leave it at that until you get insurance or whatever..............the running up and down the rpm range should really be "under load", but you can always do that later. Whatever you do after you break-in the cam..............don't let it idle.
    You are going to break-in the motor in the car?????
  2. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
  3. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    they are the moly rings. and yes it will be broken in in the car
  4. kiler be
    kiler be Member
    Culpeper, Va
    75 Maverick, 65Mustang 2+2, 03 Mach 1, 56 F-100, 99 Mazda 4x4 PU DD
    I agree. My dad was a Ford mechanic and if I did'nt know any better I would have sworn that he wrote this.
  5. Payette 302MAV
    Payette 302MAV Member
    Payette Idaho
    1970 Maverick 302 painted Bahama Blue Metallic.
    Any break in i do i would use a break in oil definatly (like royal purple, joe gibs, etc) once u start it set timing quickly and bring up ur rpms to around 2,000 for ten to twenty mins. After that shut it down drain the oil if u can afford it and replace ur oil filter. after that u should be good to run your new motor. I personaly baby my new motors for awhile haha
  6. olerodder
    olerodder Member
    NorCal
    Kiler be,
    Thanks, I'll take that as a compliment.
    My dad was a diesel mechanic, grandfather was an automotive machinest.....and me..............just a shadetree mechanic that has been working on cars/racing for some 40+ years.
  7. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    All the breakin mine got was ran it while adjusting trans then brought it up to temp once,drove it 11 miles to our little play spot and did my burn out,backed up and launched the car and about 60ft out grabbed the button(150hp shot) and ran it out the 1/8th mile then drove it home.have had no problems besides killin a stock trans in 1500 miles
  8. kiler be
    kiler be Member
    Culpeper, Va
    No problem, It was a compliment. My dad did not race him self but built many full race cars for a lot of people.
    I do miss that.
  9. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I heard a while back that you should break in the engine relatively quicky after it is brought up to operating temp. By allowing the rings to wear on the cross-hatch honing in the cylinders for an excessively long period, it creates a type of filing action against the honing and prevents it from properly seating the rings.
    "Break it in the same way you're planning to drive it."
    Again, that's just what I've heard.
    Eric
  10. strokermaverick
    strokermaverick Member
    It depends, if you have a flat tappet cam, or a roller valve trane. It also depends on what type of rings that you have. You can NOT break all engines in the same way!
