my uncle claims ot have a 351 cleveland....
Discussion in 'Technical' started by random hero, May 27, 2007.
  1. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    Actually, the Boss is only good for 363 cid (8.2 deck), according to the FRPP catalog. However, there are several other blocks (9.5 deck) that will work.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    to be exact , you DONT have to touch the towers , this mod is done , for spark plug clearence and header bolt access...
    A windsor WILL fit between the towers, but you will never change your plugs with out an engine removal!
    id recommend shock tower mod to any mav/comet owner with a V8! , and its not butching! please ask rick book or scooper77515 they both and im sure many more , have did this mod , and they have 302 based engines.
    id bet they dont mind changing plugs...
    and yes as i said earlier , C will fit better than W , C heads point down , W points right on tower...
    i love the idea of CHI (alum. C heads) on a big W , with an aftermarket block you can go all the way to 450CI maybe more , turbos, n2o and you got 2000hp
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What butchering???? :huh:
    Goes in fine.
    The tower shave (shave, not butcher) is used to make it easier to service the engine, not to help it fit.
    Here is mine, no shave, no butcher... Uses all the 302 external parts...
    Back to the discussion:
    I like the idea of a 408C for the 'wow' factor.
    Then I also like the 393W for the 'cheap' factor.
    Unless you pony up for aluminum heads, a properly built Cleveland will out power a Windsor.
  4. 73pantera
    73pantera New Member
    None
  5. Shinysideup
    Shinysideup Chillin the most
    town
    car
