off idle problems with 302
Discussion in 'Technical' started by garrettmuir1227, Aug 10, 2014.
  1. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    Isn't that block still drilled for a roller? Unless it isn't from a mustang then my knowledge falls off there lol. Yeah its a decent little setup. Forged internals all machined to match perfect.
  2. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Nope there are no holes for the keeper tray deal.
    In 82 the 302 went to a 50 oz imbalance but didn't go roller until 85.
    So my block is a 82-84........
  3. garrettmuir1227
    Temecula,CA
    ohhhh i see now. its an earlier 80s engine. well that kinda stinks, but you could retrofit it if it was worth it to you
  4. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Nah not worth it. I have a roller sitting that needs built anyways. I don't mind the flat tappet stuff my power goals are pretty mild with this setup anyways.
    The roller is getting a stroker kit and some nitrous to hopefully help it into the mid 400hp range.
  5. garrettmuir1227
    Temecula,CA
    thats my plans for this motor as well. i am already bored to .30 over, i would just need to pull the motor and install the stroker kit. may or may not build another motor instead though. and stroker or not i am getting a wet shot for this engine for sure
  6. garrettmuir1227
    Temecula,CA
    okay so progress has been made! i pulled all of the plugs today and did a compression check. all of them were just a hair under 150lbs of compression after 5 comp. strokes, so the head gasket is unlikely. i did pull off the intake today though and it looks like the water is getting into the oil via a bad gasket installer (me). the intake gasket wasn't gasketing very well and was letting water into the oil. problem solved there. so i am going to put humpty dumpty together again and continue with my tuning. but this time humpty dumpty is getting an HEI distributor, new wires, and new plugs, because i was iffy whether they were up to par. gonna cross my fingers and hope they help.
  7. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Well that's a relief anyways.
    Keep us posted.
  8. garrettmuir1227
    Temecula,CA
    can't get it to fire up with the new dist. i dont think its set on Cylinder 1. ill tinker more today
  9. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    Make sure your getting spark.
    If you are pull your number 1 plug and hand rotate or bump the motor over with the coil off until you feel your finger get pushed off of the number 1 plug hole. That will be the compression stroke on 1 and where you need to stab dizzy.
  10. garrettmuir1227
    Temecula,CA
    yeah i wired my starter switch wire from the starter to the firewall into the cab instead of factory wiring so theres not wire for me to tap under the hood lol. ill just have to run a wire down there from the battery so i can get the number one for sure
  11. Mustangnut
    Mustangnut Member
    2011 Mustang 5.0
    I normally turn it by hand with a 1/2" ratchet I don't like bumping it with my hands all up in there lol.
  12. garrettmuir1227
    Temecula,CA
    Lol probably smart of you. I like to get it ballpark with the starter then use the ratchet to get it perfect.
  13. garrettmuir1227
    Temecula,CA
    so i got it fired up, set the initial and haven't yet set the mech. advance yet or vac advance. but i did test drive it and it made a HUGE difference. takes off much much faster then it used to. run a lot better too. i can't wait to tune the dist now lol
  14. garrettmuir1227
    Temecula,CA
    Okay so i deffinitly blew a gasket somewhere. I think it might be my intake gasket. I hope. Crankcase had a ton of steam coming out after a drive. Hopefully its intake I'll keep updated
  15. garrettmuir1227
    Temecula,CA
    Steam through the valve cover vent
