Ok guys, I SERIOUSLY need your help now!
Discussion in 'General Maverick/Comet' started by MAVNWOT, Apr 6, 2005.
  1. tim keck
    sharps chapel,Tn
    1.4.10 gears
    2.ET streets
    3.3500 stall converter
    4.150 HP nitrous
    5.kick the camaro's butt
    My stocker than stock 2bbl worn out '72 Comet ran 10.15 in the 1/8,a 6 spd f-body with a good driver and bolt ons is about a high 7- mid 8 sec car at best.If he's really gonna have 400+ hp he should run mid 7's(low 12's 1/4).You should be able to take him with about 350 hp-you're lighter & easier to launch than a stick.Everything mentioned here should cost around $1,100 or less if you shop around.150 shot on my old 4dr dropped nearly 2 seconds in a 1/4-14.33/12.40 on juice.Have fun.
  2. don graham
    if your wanting 400hp. i'd think about losing the 351 heads. todays aftermarket heads are so much better and the aluminum heads are lighter. remember the less weight that you have, the less hp you need to go faster. :)
  3. J_dub
    J_dub Member
    Paducah KY
    1970 Maverick Grabber
    Id take that $500.00 and put it towards a 347 conversion.(y)
