Ride height/spring cutting
Discussion in 'General Maverick/Comet' started by x72COMETx, Dec 3, 2014.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Don't expect your ride height to change right away it take time for springs to settle
  2. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If I am not mistaken, some of the aftermarket control arms offer the "Shelby Drop" as part of their design.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Shouldn't take more than one day.
  4. mav1970
    By doing the Shelby Drop, you increase the inward angle of the top A-frame so the camber recovery begins sooner (awful angles built into a stock system) - any A-frame stock, or aftermarket, still bolted into the stock mounting holes will not increase this angle unless there is an aftermarket top A frame that uses a much taller ball joint
  5. Bryant
    my tcp upper control arms do lower the pivot point below the mounting point like the shelby drop accomplishes.
  6. mav1970
    Yep, that would accomplish it and that is one great looking Hi Tech upper control arm :thumbs2:
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    That's the one I had in mind.
    What I am grappling with is the decision whether to go with an adjustable coil over shock and these A Arms or adjust my ride height with a combo of this A Arm and remove of a section of the stock coil a small amount at a time until the car sets like I want it.
    Are those $750 "economy" coil over shocks really worth the $$$ for a car that is not Autocrossed?
  8. Bryant
    they let you adjust the shocks for anything. i can loosen the extension on the fronts for dragracing or tighten them up for handling or high speed driving. if you can afford them they are worth if they are just to pricy single adjustable will be really nice also to have. if you just want to get a low ride height and just fun street driving then some nice bilstein shocks, shelby drop, and cut springs will deliver plenty of fun on the street.
    injectedmav likes this.
