so i wanna go faster...
Discussion in 'Technical' started by lynhrt210, Sep 13, 2010.
  1. flynbrd
    flynbrd Member
    get rid of the holley 750 dp and go with a proform 650 dp or even vaccuum secondary. You'll pick up at least 20hps if your using a standard holley 750 dp. A 650 is plenty for the 306 .
  2. EZDUZIT
    EZDUZIT Member
    Spartanburg S.C.
    1972 Ford Maverick Grabber
  3. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Dude. You should smear your friends 5.0 fairly easily. My set up as of several years ago:
    Original 302 shortblock idling at about 3 PSI oil pressure :)
    Ported 69 Windsor heads, Big valves
    "Big" hyd flat tappet cam with .510/.515 lift. 230/235 Dur...
    Twisted Torker single plane... With 625 demon vac secondary's... (Bad combo I know)
    C4 with absolutely factory stall (1800 RPM or so)
    8" peg leg with 4.11s street tires.
    Beat my friends 89 5.0 notchback Stang with 5-Speed cold air intake, E Cam, and 3.55 gears by about a car and a half. I started a little behind and was running away from him at the other end.
    A few years later I made these changes to my car:
    Air Gap dual plane intake with Holley 650 DP. (WAY Better combo)
    9" rear 3.70s with Detroit locker.
    Ditched C4 for a T-5.
    Oh, and now idling at 2 PSI oil pressure :)
    Raced a similar equipped 88 5.0 5-speed and beat him so bad I thought he broke his car :)
  4. justin has a 74
    kentucky
    Why torker 2?
