Valve covers?
Discussion in 'General Maverick/Comet' started by Darwin'sheros, Nov 18, 2009.
  1. Darwin'sheros
    Darwin'sheros Member
    Layton, UT
    1974 302 Maverick
    I put in an edelbrock intake manifold and carburetor a while back but I'm faced with a problem. The linkage hits the valve covers, so we put a spacer under the carburetor. Now the carburetor hits the roof.
    I don't want to cut my hood or change it (I hate cowl hoods and I don't have the kind of cash to get one and then paint it!) so I was wondering if there were any valve covers that would slant about an inch or so to the side from stock? My neighbor says they make a pair like the boss/cleveland valve covers but I can't find any.
    I guess I'm asking if you can bolt 302c valve covers up to a 302w or if there are valve covers with a similar design.
    Can anyone help?
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    I think newer mustang might help yu out they are more rounded at the top .
    I have a pair
  3. maverick maniac
    owensboro ky
    I think he is talking about the linkage that is on the carb ???
  4. Darwin'sheros
    Layton, UT
    1974 302 Maverick
    So then the EFI valve covers from the 80s will work? I thought they wouldn't cause they only have the hole on one valve cover?
  5. Joe Dirt
    post pics of the problem please having hard time seeing it in my head
  6. Bryant
    i have not seen any carb linkage combinations that can hit the valve cover. a pic will help or a beter more detailed description. also do you have a drop base air cleaner or a flat one.
  7. maverick75
    x2!! I dont see how its possible. I was running a 4160 with 1 inch spacer and 14 x 4 air cleaner with tall valve covers and it fit under the stock hood.
  8. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I would say go with a drop air cleaner base, but what part of it is hitting, is it just the stud in the middle or the whole assembly? Because that is pretty much the setup I am running now, a 625 cfm carter on a 1" spacer on a edelbrock performer intake, using a moroso drop air cleaner that even clears the thermatic choke.
  9. 71gold
    I,m with Joe....
    :ttiwwp:
  10. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    :Handshake I’d like to see pics too! Only because if I remember right this was a pretty nice car and Maverick or Comet sightings are rare to none in here Utah. I’m beginning to think I’ll see Bigfoot before I see another Maverick or Comet pass, park near me, of pass me.
  11. mavgrab302
    My carb linkage hit my maverick valve covers,I had to put a one inch spacer under my edelbrock carb....The hood shuts fine....
